Little upgrade
    Little upgrade
    Was time to add Bluetooth. So got to rewire everything that I just wired up a few years ago. The original head unit was in the glove box with a remote over by the steering wheel. Mounted new Kicker Media Center in place of the remote and then had to fish all the wires over from the locker to the helm. Almost just put in the WS Bluetooth controller but went a head and went for the all in one.
    Had to fill in the old hole in the glove box, so added a little storage. I'm no fiberglass man so not 100% as pretty as it could be but its very functional.
    Looks good. Great work!
    You're crew will love your hard work.
      Awesome job, looks like a super clean install.
        Looks good,
        I don't think you used enough screws :P lol jk
          Install looks good! Is the kicker unit Bluetooth only or do you have an aux cord or something for an iPhone or what not as well?
            Looking at Crutchfield, it looks like it has a RCA AUX input and a usb input (iPhone Compatable) in the rear.
              http://www.kicker.com/KMC10
              AM/FM
              Weather Band
              BT
              USB that will stream as well as charge a phone
              Nameable AUX input
              EEPROM memory
              Battery monitor
              Dual zone volume
              dual input
              Two wired remote options
              Can power four 4 ohm speakers
              The step up the KMC20 and an even more budget friendly model is the KMC2 compact media center
              Here are some pics of the KMC20 and its black box control center. http://www.tigeowners.com/forum/show...des&highlight=
                Originally posted by Greeko View Post
                Looks good,
                Haha like I said not pretty but functional
                  AM/FM
                  Weather Band
                  BT
                  Nameable AUX input
                  EEPROM memory
                  Battery monitor
                  Dual zone volume
                  dual input
                  The KMC2 is a nice little unit just wouldn't cover the existing hole I had in the dash from the very first factory remote, so went 1 step up to the KMC10.
                    If anyone else find themselves at this same crossroad, even with a transom remote, cut a filler plate that sandwiches between the unit and boat. Inner hole matches the new unit, OD large enough to encompass the original hole as well as any footprint left behind. if a bushing is needed to counter some slack, cut its OD to the same OD as the larger original hole.
                      Tricks of the trade, I like it plus save $
                      This hole was rectangular though so would have looked a touch off, the original installer of the old JVC unit really cut a rough hole.
