actually ported would need a larger box than sealed.....box looks to be about 1cuft, which as a sealed box is just about right for that sub. A little on the small side, but nothing that some polyfill can't take care of. Wetsounds wants 1.18 and you can make up that difference pretty easily with poly.
suggestions for stock Tower of Power upgrade?
This is a great tip. From some quick reading, it looks like I need about 1 lb of polyfil for a 1cuft enclosure. Do I need to keep the polyfill away from the speaker driver? Or do I just stuff it in?Originally posted by tommy1005 View Postactually ported would need a larger box than sealed.....box looks to be about 1cuft, which as a sealed box is just about right for that sub. A little on the small side, but nothing that some polyfill can't take care of. Wetsounds wants 1.18 and you can make up that difference pretty easily with poly.
IF you wanted to use some, just loosely fill the enclosure to about 75%. Polly fill will compensate for a too small enclosure by absorbing the radiation off the back of the cone. The cool thing about a sealed box, they are sooo forgiving. A little small and its kinda peaky. A little too large, its more mellow. I would not worry about adding polly fill unless your box is really below the recommended sealed size.Originally posted by Duncan View PostThis is a great tip. From some quick reading, it looks like I need about 1 lb of polyfil for a 1cuft enclosure. Do I need to keep the polyfill away from the speaker driver? Or do I just stuff it in?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
