Well looks like pro 60s coming down,upgrading to xxx 12 sub.Any suggestions where to put it. Under drivers side has 10 fa and 1 650 ,not much room for sub box ,if i were to sub it out ,with computer box and other stuff up there.Thanks again.Ride 2011 z1.
xxx sub
If the XXX is going under the helm and be radiating directly out into the cabin, then I would not worry about using the XS10fa. If you wanted to still use it, im not sure where to best put it. It would make for a great boat-shaker if stored under a seat or in a locker.Originally posted by dyycon View PostDU'' I guess if i would have read jzts 0214 on xxx install that would have solved my question. Heres another one should i use the 10 fa sub and relocate it or just not use it . Thanks again.
If used a free-air and face it out into the cabin, you can run into some phasing issues with the XXX.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
