I am having usb problems with my iphone/ and ipod on the clarion cmd6. Error 5 mess when i connect. I have reset both iphone and ipod 1 out of 20 times it works. Is there any thing else i can do to fix the error 5.
clarion cmd6 usb problems
http://www.clarion.com/us/en/support...ine/index.html
First check the Ipod compatibility list. Next thing I would recommend would be to relocate the small red remote turn-on wire for the head-unit from the ACC terminal of the key switch to a rocker switch. This way the system doesn't power down when the engine is turned off and then the key is turned to the ACC position and powered back up.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Well, my gut tells me that your head-unit is wired to the key switch and is on in either the "Run" or "ACC" position. When you shut the engine off and turn the key counter-clockwise to the ACC position so you can still listen to the tunes, the head-unit is momentarily turned off then back on. This forced it to reconnect with the USB, AUX or SAT device. This could be contributing to your issue. I would recommend moving this little red wire to a rocker switch. This way, you can turn the stereo on and will will stay on till you turn the rocker switch off. However, I do suggest using a rocker with an LED.Originally posted by tdavidson View PostThank you.
i checked the compatibility list, and that should be good. Now what is the rocker switch?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
