Apparently Liquid Nail must have changed substantially, b/c I just used some to glue up some Trex boards to my hull as I'm redoing my amp rack. I Ran some 2x4's across to the wall Tige has set-up for your amps, to wedge them in and give a good bond with the glue. I came back 4 days later and NOTHING was holding. I removed the wedges and could slide the boards with ease! Admittedly, we've had some high humidity lately, but 4 days should have been enough to cure I would think. It did not bond the Fiberglass AT ALL! When I pulled the board off, the glue all stuck to the board and none stuck to the fiberglass.
Being the weekend I was limited to where I could go. So next I'm trying some PL375. I'm kind of worried about the 375 not getting hard enough though. I couldn't find 400 like I would have liked to use. Guess we'll see what happens! If this doesn't work, I guess it's onto Epoxy (gorilla glue).
Really trying to avoid fiberglassing the damn things in. Blah!
No exposed fiberglass anymore
Just solid marine plywood to screw to! FINALLY! I wish tige would figure out that 95% of us want our amps on that outside wall.... not the inside wall! Now I just gotta carpet, route my wiring, set up my relays and LEDS, and done!
