Wetsounds with LEDs upgrade?
    I’d like to upgrade my 2013 Z1 Wet Sounds with LED versions. I have the Alpha Z tower. Is this (easily) possible?
    You will need to pull wire through the tower, for the LEDs. Next, you will need to have the Rev series or Icon tower speakers in order to the use the available LED ring kits. If you have the older Pro series tower speakers, you would need to have custom rings made.
    If you are not sure which model you have, post a somewhat close up pic of the speaker side of the pod.
