eld.gg How to Save and Score More Penalties in FC 26
    Few moments in FC 26 are more frustrating than guessing the correct corner on a penalty and still conceding. From the goalkeeper’s perspective, it feels unfair: you read the shooter, dive the right way, and the ball still ends up in the net. This is not bad luck or broken mechanics. It is the result of how the FC 26 penalty system with FUT 26 Coins actually works-and once you understand it, both saving and taking penalties becomes far more consistent.
    Why Goalkeepers Guess Right but Still Concede
    The core issue lies in decision timing. In FC 26, penalty aiming is locked in much earlier than most players realize. Unlike older FIFA titles, there is no visible aiming reticle, and the left stick no longer resets to neutral when released. Once the shooter commits to a direction, that decision is effectively final.
    Because of this, reacting late as a goalkeeper is punished heavily. If you wait to see the shot animation before diving, you are already too late-even if you dive into the correct corner. The goalkeeper simply does not get the necessary reach or animation priority to make the save.
    This is why you often see the ball traveling while the keeper is still standing upright. The input was correct, but it was registered too late.
    Understanding the FC 26 Penalty Zones
    Since FC 24, goalkeepers must also decide between five distinct zones:
    · Top left
    · Top right
    · Bottom left
    · Bottom right
    · Center
    These zones require both direction and height commitment. A correct left/right guess without the correct high/low input results in no save animation. The game rewards early, decisive inputs rather than reactive ones.
    The Correct Way to Save Penalties
    To save penalties consistently in FC 26, you must commit before the shooter strikes the ball.
    1.Decide Early
    Make your choice during the run-up, not after the shot. The shooter cannot change direction late, so you are not giving anything away by committing early.
    2.Use the Left Stick First
    Slightly move the left stick toward your chosen side during the run-up. This creates a small lateral step that increases reach.
    3.Trigger the Dive with the Right Stick
    Flick the right stick in the same direction to activate the full dive animation. Do not flick once and wait-multiple quick flicks help ensure the animation triggers reliably.
    4.Timing Is Critical
    Your goalkeeper should already be moving and beginning the dive just before the ball is struck. If the ball is already traveling and your keeper is still stationary, the save will not happen.
    When done correctly, you will notice a clear difference: earlier animation, greater reach, and significantly more saves-even against powerful shots.
    How to Take Better Penalties
    Understanding this system also helps you score more penalties, especially against opponents who commit too late.
    1.Watch the Composure Ring
    Begin powering up as the composure ring drops, aiming for a clean release. Perfection is not required, but avoid rushing.
    2.Use More Power
    Three bars or slightly more is ideal. Higher power reduces goalkeeper reaction time and makes saves less likely, even when the corner is guessed correctly.
    3.Delay Your Final Aim Slightly
    Holding the aim fully toward a corner for too long increases the risk of hitting the post due to placement error. Instead, wait briefly during the run-up before committing.
    4.Commit Once, Then Trust It
    Once you decide on a corner, fully aim in that direction and do not attempt to adjust late. The system does not allow meaningful late changes anyway.
    Well-placed, powerful penalties to the corners remain extremely difficult to save unless the goalkeeper commits early and correctly.
    Key Takeaway
    Penalties in FC 26 are not about reactions-they are about anticipation and commitment. Goalkeepers must decide early and trigger animations before the shot. Penalty takers should use power, controlled timing, and late commitment to placement.
    Master these principles with cheap EAFC 26 Coins, and penalty shootouts will shift from a coin flip into a clear competitive advantage.
