Hey guys (and gals if there's any out there)...
Quick question...hopefully we don't get rants about the regular towing topics but I figured I would see if anyone else has dealt with the issue of the 1/2 ton trucks coming stock with class III hitches.
I just bought the R23 and it seems to weigh out around 6,200lbs or so completely empty. So, knowing my 2015 F150 came stock with a class III hitch and I don't want to buy a new truck over this, here in lies the dilemma.
Now, I should have looked at my hitch capacity but I really never thought it to be an concern until I rolled under the truck and found the hitch is only rated to pull 5,000 w/ 500lbs of weight on it (unless using a WDH). Now who uses a WDH with a wakeboard boat? Answer, no one that I have seen. I'm guessing that all those other guys I see pull up to the ramp with these larger boats are just ignoring their hitch rating capacity and taking the chance that nothing ever gets said.
Now, before I get a lecture on GVWR vs. hitch vs. all the other ratings we see in our manuals, I'm pretty up on what all of this means. On F150 forum, there's a post from a guy who got blasted with lots of emails (with bad info) on this subject so I guess I'm trying to avoid this type of discussion and arguments if possible. I know the what the "truck" is rated for vs. the hitch. The truck (drive train, frame, wheels, etc) can handle the extra weight and the boat is VERY light on tongue weight if not too light so it's not even that. I'm sure the class III can take this boat but if the lawyers get involved, well that's just not something I feel like dealing with.
I'm just trying to find out what others have done or IF there is anyone else out there who has dealt with this issue.
From what I can see, I have three options:
1. Buy the Curt class IV hitch that sits below the stock hitch to raise my "hitch" rating to a true class IV (1,000 tongue,10,000 pulling). BTW, I called them and confirmed all of the above and the fact that this hitch does NOT put me over my trucks pulling and loading limits but rather increases the tongue and pulling capacity which the weakest link in this case is the stock hitch. IMO, this is the hitch Ford should have installed as it doesn't go past the loading limit of the axles, tires, rims, chassis, etc but give us a little more room for this situation. Pros, easy install and cheap. Cons, looks like crap and decreases my ground clearance in the rear.
2. Remove the stock bumper/hitch assembly and purchase a new assembly w/o the stock hitch (Ford p/n HL3Z17D826D) , basically taking my stock hitch off then and buy the Curt (or similar) class IV hitch and install them both. Pros being it will look and function on the truck a lot better. Cons, more $$ and more work.
3. Just run it like it is and take the chance that if in an accident, my insurance company doesn't claim I'm at fault for not having the proper equipment. Pros, nothing to do but loose sleep when going down a steep mountain hill at 65mph. Cons...well I think you get the idea.
Is there anyone else here that has dealt with this successfully? Personally, I'm leaning towards option 2.
. This sucks. Easy to take off but getting them back on is a PITA because they are only held on by plastic tabs that like to fold over like your interior trim. Damn you Ford!.
