Wheel Bearing and Rotor Removal
    I had a tire blow out last time I towed the boat to the lake. After the blowout, dropping the boat at the lake and bringing the trailer back to the house I found that after the blow out the trailer oil bath wheel bearing is now leaking.
    I am now trying to remove the bearing from and rotor from the trailer and having a problem. Any suggestions?
    2004 Extreme Dual axle trailer.
    Is it the inside bearing thats the issue..meaning backside... probably got hot and fused to the spline possibly... if a rubber malott wont break it free.. you can try taking a torch to heat it up and see if that helps I assume it wont come off the shaft is your issue.
    2011 Tigé RZ4
    www.re-viveupholstery.com
      Problem is that the oil is leaking from the oil bath unit at the front. So if I fill the oil bath cover it leaks all over the wheel.
