weighting, taps, & rope length on 21V
    JUST CURIOUS.....
    How are you with 21V's weighting your boat??
    What effect does taps play for you?
    I usually run two 275lbs sacs in the rear compartments pushed all the forward under lounge seats as far as they go....(to match drivers side)
    One 275 lbs in the walkway.
    Two 150lbs sacs up front under the seats.
    Taps anywhere from 0-3 depending on boat speed & water calmness.(which usually relate to each other)
    Wake is hard & very rampy.
    I like riding at about 25 mph in calm water and 75' rope length.
    For surfin, I transfer the middle sac to the rear corner, throw all the people on the same corner sun deck..... & it rips!!!!!
    We usually have a min of 4 people on board.
    This thread displayed a lot of peoples weight setup, length etc.
    Also, what speed do you find appropriate for surfing?
    Seems like Tiges need a faster speed. For me it is anywhere from 13-14 mph.
      Matt,
      We surf at about 9.5-10 mph.
      the more people/weight...the higher the intial wave.....and longer aswell...so you can really get back thier and surf back in.
