Rudder Rebuild?
    Rudder Rebuild?
    I have a 2004 22V and my steering is very tight under throttle. I have a new steering cable and it turns very smooth at idle which makes me think my rudder needs rebuilt. Are there any tricks to this, or advice before I tear into it?
    Have you greased it lately?
    Oh Yeah!
      I did grease it when I changed the cable. There is a small amount of play in it when I pull the rudder back and forth, would this cause it to become tight when there s pressure on it under throttle?
        Yes, yes it will. Was the shaft worn? You may be better off replacing the whole rudder assembly.
        Oh Yeah!
