Wakeboard set up 2015 z3
    Hey everyone, so I kind of figured out the wakesurf settings but can anyone give me a base set up for wake boarding? Speed/ballast front to back, side to side? Avx taps plate #?
    Thanks
    Brian
    We don't wake board but I'll give a starting point for ya - others may have a little better setup however...
    AVX won't be deployed over ~12mph. 100% front ballast/50% rears. ~20 mph with taps at 6 - you can move taps down to clean up the wake.
    Hope that helps a little!
      Thank you, I don’t have taps I only have Avx.
        TAPS2 is the center plate in the middle. That plate is used for all aspects of your boating at any speed and has a range from 1 to 8. 1 is all the way down and 8 is up.
        Your AVX is for surfing only. It will deploy around ~7 mph and cleans up the wave very nicely. Same as TAPS, 1 is all the way down and 10 is all the way up.
        If that doesn't clean things up a bit, let us know!
          Thank you for the explanation
