This should be easy to find, but I can’t seem to locate the mefi diagnostic port on my 06 24ve. Seems like all connectors I could plug into already have something plugged in. I thought it would be simple to locate like the OBD port in a car, but I can’t seem to locate. Anyone know where I plug in?
MEFI Port on 2006 Marine Power
Tigé Jedi- Jul 2010
- 4305
- TN USA
IIRC 2006 was the "transition year" for MEFI/CAN, meaning some boat engines had it and some didn't. I'm told by 2007 you could reliably presume MEFI/CAN was on all new engines. This is one reason we set a baseline year of 2007 for the R&D boat we're looking for, we must have MEFI/CAN. In other words, are you certain your 2006 engine DOES have MEFI and thus a CAN diagnostic connector?
Boone, this probably isnt going to help because this boat is an 08 22ve with MP340. Pretty sure its got a newer MEFI 4 or 5 ECM (three plugs and big aluminum case with cooling fins). It has the newer style connector. Prettu sure yours is the older more square plug for older versions of MEFI.
Plug was on stbd rear of motor kind of near distributor. I think you are different tho
a hit freelancers swear by exercises — washing your face, putting on real garments and placing smartphone boundaries — and thoserecommendations increase to ingesting. dietary therapist and longtime paintings-from-homer wilma macdonald told huffpost that snacking right here and there's the largest mistake she sees new far flung workers make. she recommends setting up your day like all everyday working day, with a lunch wreck, a few smaller breaks and a focus at the most important meal: breakfast.
voip phone service
