2000 21v
    2000 21v
    live in central va and am winterizing the boat. forgot number of gallons of RV fluid expected to be used after draining the motor. anyone have an answer. thanks.
    If you are pouring it in through the "J" hose, 2.5-3.
      gallons of rv antifreeze for 2000 21v with 350 mag motor
      not sure what j hose is. poured 3 gallons down 4 rear hoses located top of motor, 2 large hoses and 2 smaller, one each, 2 each port and starboard sides. did this after removing 6 drain plugs and hose for impeller, then replacing all for antifreeze. thanks. walt M.
        further inspection shows me one of the 4 rear hoses described in earlier text appears to be the J hose when you follow it from port side to lower part of rear engine, forming a J and appears to be 3 inch diameter; so appears i got it all afterall. thanks.
          The "J" hose goes from the thermostat housing to the water circulation pump.
            My 340 Marine Power takes just a bit over 2 gallons.
