I need new gauges I’m thinking Faria Breede Chesapeake gauges in black or white question is does anyone know of a part number of a adapter so I can pull the old 4” faria pilot out and put in a 2” depth finder attached to the existing transducer and I plan on putting the white or black stargazer 2 line gauge in place of Speedo here’s my current garbo gauges The taps gauge works but I have to tap on it the oil and volt and speedo work nothing else really need the temp gauge makes me nervous F55314F7-FD2C-4EAA-8F0D-DA5593C6B06B.jpg
2001 2300v gauges
i did tighten everything up two of the four work on my multi gauge so i don't think that one's a ground the speedo didn't work but after fiddling with the wires it works the pilot gauge turns on but its a eye sore i think i should run a ground block off battery i really wanna eliminate the pilot gauge but all the depth temp gauges i've seen are 2" i need an adapter from 4"-2"
My 2001 has the chesapeake gauges. I would try a temporary ground direct to the battery on each gauge just to be certain its not a grounding issue. I would also check continuity on the wire from the sending units. Not sure about a 4" to 2" adapter but you could use a 4" blank and then cut a hole in that for the new 2".
https://www.amazon.com/Faria-Black-B.../dp/B00EVIICCU
thanks for reply i'll try independent ground from batt do you know which wire on the motor is the tach wire and do you know how to test temp sensorOriginally posted by surfidaho View PostMy 2001 has the chesapeake gauges. I would try a temporary ground direct to the battery on each gauge just to be certain its not a grounding issue. I would also check continuity on the wire from the sending units. Not sure about a 4" to 2" adapter but you could use a 4" blank and then cut a hole in that for the new 2".
