Hey Guys,
I just changed my water pump and I have 2 questions.
1. How much tension needs to be on the belt? I have read a 1/4" give on the longest point of the belt
2. I have water coming in the engine compartment when I ran it. I only ran it for 10 minutes on the trailer backed down the ramp at a nearby launch point. The water pump I just changed, does not appear to be leaking.
This boat is new to me and ski boats in general, not sure what is acceptable amount of water, if any.
It did not go all the way up to the back of the engine, and it appeared to come in, and not fill any more after it came in.
Thanks!
Thanks!
but it needs to be fairly tight. Too tight it will eat the belt and too loose it will squeak when it slips. For only 10 minutes you shouldn't have had really any water in the boat, unless there was rain water or something in there and it all went to the back when you went down the ramp. I'd start by checking to make sure all the drain plugs in the motor/exhaust are in, really easy to miss one de-winterizing. If that's not the case check the shaft packing see if its leaking, or just start looking around for the leak.
