Just a thought I am having about the built in cooler for my 24V that looks like a kidney. I think it is a great idea to have it integrated but it doesn't hold much and the ice barely makes the hr drive from the house. I did a search and saw a post from stingreye that he removed his in his 22V and is happy. I am wondering if anybody else has removed theirs or even just insulated the space better and kept it. Another idea I had was to take out and use the space for one of the bag cooler like AO or something to that effect. That way I may be able to have more capacity also. I'm open ears to any and all suggestions. If anybody has pictures that would be sweet too. Thanks in advance.
Cooler Removal/Suggestions
Seen a few boats with in removed first hand, it does allow for more space. I still have my kidney cooler in mine I use it as a trash can and just use my big AO cooler and keep in under the bow filler so its out of the sun.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
That's why I am thinking of taking it out. I have a feeling it is bare glass under so I would have to finish it off with some carpet. Then put an AO cooler in that space. The good news is that AO and many other companies are sponsoring the reunion so I can get a good look at this stuff other than the Internet. Wonder if they will have a couple things to sell...either way it's gonna be a good time.
Ive taken a bunch out for the purpose of doing the audio work. Yes, its unfinished under there. It would be easy to finish it with carpet, install a edge guard around the opening and make it a locker. If the decj cap is white, it would be easy to fill the screw holes and hardly know they were there.Originally posted by dmaxx04 View PostWith the ones you have seen, was it bare glass under it?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
After making better use of my built in cooler I got a AO Cooler that fits perfectly under my bow center cushion. This is the best boat cooler for those with the dead space under bow cushion. It's actually the best cooler I have and was less $100.
https://www.aocoolers.com/38-pack-st...ler-black.html
The stock "kidney" cooler already has about an inch and a half of insulating foam on the other side. It's the seat tops lack of a good seal/insulation that allows the ice to melt so quick. Lose the kidney and make use of the space as a locker for whatever you want. It's a pretty good size space under there, much bigger than the shape of the cooler.Originally posted by dmaxx04 View PostThanks for the info. I had a feeling you would have experience with removing them. I also thought about getting the foam in a can to spray in there to insulate the cooler.
