We have a beeping alarm that beeps twice then goes away. The alarm returns and cannot see where it is. Thought it was the trans temp. Replaced the switch, cleaned the cooler, changed water pump, and changed the trans fluid. To confirm the alarm unplugged the switch and still got the alarm. It is not the trans temp. Where do I go from here?
2004 22ve alarm that I cannot find
Only happens while running? Every couple of minutes? All fluid levels and gauges check out fine? I have the same thing going on right now. I've talked to Faria and they say to unplug the multi plug from the back of each guage (tach/speedo) separately to try to narrow down which its coming from.. I haven't done it yet, but my guess is going to be speedo, as I had my tach rebuilt over the winter so it's new... I haven't gotten a chance to check mine, so let me know what you find if you don't care....
EDIT: I should add that I also checked everything you did and took it to my mechanic to plug it into a diacom. He scanned everything looking for a code or anything that would b tripping the alarm, and found nothing. This led me to a faulty guage. The reason I had Faria rebuild the tach over the winter was because it started a beeping frenzy last Labor Day weekend, but it was a different beep. The lighting circuit in it went haywire so it had a constant beep beep beep anytime the key was on... The same beep you get when you brighten or dim the guage lights... Hope any of this helps you outLast edited by Bryan; 08-09-2016, 09:39 PM.
So the temp sending unit went bad but the guage still read normal???Originally posted by Matthew4124 View PostI had the same issue and it was heat sensor! Dealership said that heat sensor went bad but didnt affect temp gauge or operating temp! Also they said if it wasn't that to check the oil pressure sensor!
OP - did you solve your alarm issue? It sounds like we had the same alarm, and mine ended up being the Idle Air Control Valve.. All is good now. Here's a link to my thread about it.. It also has part numbers and directions from user CDawg on how to change it..
http://www.tigeowners.com/forum/show...0-Random-Beeps
