Tige re-prop? 2003 24ve
    I recently picked up a 2003 Tige 24ve in excellent condition. Took it out for the second time yesterday, and I noticed that when running with ballast and with only 3 people in the boat it works pretty hard to get up and moving. Im thinking I need to re-prop for the weight? What would be the ideal prop for this.
    Engine is a 5.7 L, and run around 1200 lbs in the rear.
    Currently without ballast it takes around 10-12 seconds to get up to top speed ( around 34-37mph).
    My main use is for wakeboarding and surfing with the occasional tubing, just trying to get the details worked out on this beast, any recommendations would be fantastic!
    What is your current prop? It's stamped on it.
      current prop is a 13.5 x 17.5 L
        Lake Elevation?
        Blue (1.48:1 gear) or black (1:1 gear) v-drive?
        Current prop 3 or 4 bade?
