Hey guys after a long wait I'm finally in the tige family. Everything seemed great when I bought the boat and after one day on the water I figured out all kinds of new stuff. The engine won't idle after it's been running very long. At first start up it was fine unloading and stuff but after burning about half a tank it wants to die and does some after I put it in neutral I barely even got it loaded. The rpms struggle from 100-700 trying to stay running. So that's first issue secondly it started cutting out making a loud tin can noise on the way back. Almost sounded like a Coke can was in my engine and it would rattle every now an again like it was flying around in the bed of your truck. It doesn't sound good at all. Lastly I got it home and the radio won't turn on at all. Lights works and all the switches and the clarion will try to eject a disc when opened but the screen won't power on at all?
Glad to be a tige owner just gotta get over these humps. The boat has the 343 Pcm Excalibur engine. Any help would be great. I have checked the oil and it's good and looked for all the fuses I could. Other than that I'm new to it and don't know where to start. Thanks guys!
just kidding can you isolate the sound? I had a ringing/tin can noise on mine when I got it, for me it was simple clamp that holds my transcooler that was loose. COULD be just that simple. Sounds like you have little gremlin in there, well help you find him.
