i just picked up a 2008 Tige Z21 and need prop suggestion
    i just picked up a 2008 Tige Z21 and need prop suggestion. I noticed that i have a small bend on one of the fins and should see if I should repair and or upgrade to a better prop for performance? i presently have a 537 13.5 x 16 Y L 1-1/8"
    Thank you
    Mark
    The 537 is a decent all around prop, but if you are going to purchase a replacement, might as well consider an upgrade that might be better suited for how the average tige is used. Some basic info needed:
    engine and HP
    lake elevation
    ballast and normal crew size. The 08 Z1 would have come with 900 factory lbs in ballast, so if you are serious about surfing and boarding, you will want more.
      Call Acme, tell them waht your needs are and they will get you the exact prop
      refurbing a prop is about 50% of the cost of a new one(at least in my area)
