11 RZ4 PCM 343 performance
    Would there be any concerns about performance/gas consumption on this setup with full surf ballasts? What about prop considerations?
    Thanks
    What would be the elevation of the normal lake? Yes, I would suggest a prop upgrade form the stock ACME 537 when loaded for surfing.
      which prop?
      681 at Full
      currently 668, was as low as 614 pre Memorial Day
        Our 24Ve (same length, very similar hull to your RZ4) with the same engine definitely benefitted from a prop upgrade from the factory's 537. We went with the 1235 at Acme's recommendation and it works great. We're around 2000 MSL.
          So basically sea level as far as the engine is concerned. I would not worry about that engine/boat package at all.
