Need some advice on an issue.
Hit a deadhead while surfing yesterday; vibration was present, Idled back to the dock. This morning (daylight) found my issues.
Prop was slightly wacked and wobbled on the shaft. Keyway was damaged and the guys at Precision Propeller (Spokane Wa.) were great at repairing the prop as I waited; just aligned.
I did notice that the cutlass bearing is definitely worn, as there are gaps on side (both ends).
And there is daylight where the "rope sleve" is supposed to be.
So I read as many threads as I could (Worsty's from 2013 was great - but I called the shop and he claimed Tige changed forgers for the strut after 2004 so he didn't have the right cutlass bearing. I was told that it is easier to remove the strut than the prop shaft but checking the measurements from the end of the shaft to the rudder, the numbers don't add up.
I would call the local Tige dealer for the part (oh right I don't have a local Tige dealer) but since I called six different dealers in three states and only got one to respond to a replacement pop up cleat, I hesitate to go down that road again.
Where does one get the correct cutlass bearing(s) and does anyone have any tips (pics) on removing the shaft and or strut?
Thanks,
Paul
Thanks,
Paul
- please share!
