Dumb Oil weight question
    I tried to do a search on oil weight but it seems like answers are all over the place.
    I have a 350 MAG MPI - the service manual says to use 4 Cycle 25W40 Engine Oil
    My buddy uses Shell Rotella T 15w-40 in his. So here is my question.
    The local walmar has Shell Rotella T 15W-40 Heavy Duty Diesel Oil - Is that the same thing - (Diesel Oil?? never heard of it)....also - is normal oil the same as 4Cycle oil?
    Sorry - I kind of an idiot when it comes to things like this....Im a diy'er for the most part - but and curious about this.
    Thanks
    When dealing with diesel HD usually means high detergent not heavy duty. I would not suggest HD diesel oil. Yes 4 cycle is normal car engine oil.
      I use Pennzoil Marine 15w40.
        I use exactly what the book says....Quicksilver 25W-40 or is is Mercruiser 25W-40...If I wasn't at work I could tell you..lol. Either way I follow the book even though it does cost a bit more.
          Thanks
          Walmart sells Quicksilver 25w-40 marine engine oil.
          dont use rotella....that's a Diesel engine oil...high detergent as others have stated.
          Use the weight your manual specifies.
          Bad decisions make good stories.
