Yah same way I felt also.. Its pretty shitty.. What color is your boat ? If your boats black just tell them that.. Whats the dealers name and contact Id love to call and have a convo with them
2008 Rz2 tige platform
I can help you get the brackets mounted up.. Cause the Z3 platform is smooth top and bottom.. The RZ2 2013 and down is not smooth.. And I tell him this cause its excatly what I would do if I could do it over again.. I have like 30 hours in my platform.. The time I wasted I could of bought the z3 platform witch if alot like my end result. If to get the convex he will end up spending 4K++++www.1320diesel.com Home of the Fastest Diesels!
The bottom of the platform doesn't matter with the VX right? I'm concerned about the VX lining up with the hull shape, the z3 has a different transom shape from the RZ2. All he should need to do is unbolt his old brackets, see where the new ones need to go, see if the old holes can be used or seal the old ones and drill new ones. Unless there is a picture to show the convex VX fits the same bottom profile from the Z3 to the RZ2, I would order the RZ2 parts.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Correct, so why would he order the Z3 and try to McGuyver it to fit the RZ2?Originally posted by Timmy! View PostIf he's going to do a VX, you order the whole shootin match, brackets, platform and VX.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Here's a question - if the Z3 platform performed better on the RZ2 than the current one, why wouldn't Tige just use it? Why go through all of that hassle to make a separate platform for the RZ2/4 if the other one performs better? The RZR/Z3 have the same design. I'm guessing that there is nothing wrong with the current RZ2 platform and they like the design/look of it better than the rounded corner Z3 version.
Are we talking about just the swim platform or the entire swim platform with convex VX? If its with the convex VX then the bottom doesn't matter but if its just the platform then I can see how the new platform makes a difference. But I still wonder if the z3 platform will line up against the transom and if not how much cutting and and glasswork will be required to make it fit like the factory platform.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
in response to the tell them you have a Z3 comment...
