Originally posted by dingleberry
View Post
Steering Cable
I know n my 2008 20v after 2 years the cable got stiff and needed replaced. When I took it back to where I bought it they mentioned an electrolysis problem they attached a ground cable to the steering cable and grounded it to the engine and I have never had the problem again. You could give it a try with your new cable.
Tigé Jedi- Jul 2010
- 4274
- TN USA
There have been some comments regarding the importance of proper grounding on steering cables, and its effect on longevity. I originally presumed this was mostly an issue in salt/brackish water but apparently there is enough electrolysis with fresh water too. Might want to make certain things are grounded properly when doing the install. Just a thought.
Tigé Jedi- Jul 2010
- 4274
- TN USA
Sparked? Normally electrolysis involves a very small voltage potential. Sparking requires a lot of potential difference.Originally posted by Greg Mallek View PostTell me more about the electrolysis issue. Mine accually sparked when I was cutting out the old one. Looks like I need a grounding cable (?) How and where would it attach? Any pictures out there?
Thanks
In any case, the bracket to which the cable mounts back by the rudder should have a ground lead running to it. Here's a photo of mine:
You should have a similar setup, with wires connecting essentially everything metal to each other (including engine, rudder, steering, etc.). The idea is to prevent voltage potential differences. No voltage = no current flow = no electrolysis. One of the few times in life you intentionally want a short-circuit!
Does your boat have something like the above happening around the steering cable/bracket assembly?
Tigé Jedi- Jul 2010
- 4274
- TN USA
Could be. I'll ask. They're coastal, so electrolysis is a much bigger deal for them and most of their customers than for me with my inland fresh water. Glad to have the wires, though!
It's time!Originally posted by dingleberry View PostNobody - unless the cable on your '08 is routed differently than my '09, you will want a 21-ft cable for an RZ4. I just replaced mine, and Andrew called Tige to verify the length since my marking were illegible. Unfortunately, they told him 19-ft, but there was absolutely no way that it could work following the factory routing. Got a 21-footer, and it worked perfectly. Measured the old one once I had cut and removed it. And it was 21-ft from the factory.
Thanks Ding!!
