New owner of a 2005 21i
    Hello, I’m super excited to have just purchased this boat and took it out today and had some issues that someone may know the answer to. First, the speedometer wasn’t working. Second, the gas gage went up/down and all around really. I filled it up after I left so not sure if that’ll solve it, only put 13 gallons in. Third, the little Sony radio controls weren’t lit up. Not sure if there’s an issue there or not. Fourth, the original owner stated that the rear seat can be turned to be an observer to watch riders, how do I do that. Also, if you have a video that breaks down the inside of the boat, that would also be cool. I can’t find anything on YouTube. Any info would be appreciated!
    Most likely your speed read by a paddle wheel in on the transom. I would check to make sure that the wheel spins freely and is not missing a paddle. I am assuming that the speedo is a Faire Beade with the up and down buttons and digital read out in between?
    As for the fuel gauge, check the wiring to make sure it has good connections especially around the tank side.
    Factory head unit was a Clarion unit so you will have to check the manual for available functions
