Data port... HELP!
    Data port... HELP!
    My mechanic cannot find the data port on my '06 22ve. The engine (Marine Power 6.0L) has been stalling out and he needs to hook it up to see what engine diagnostic codes show up. He has looked in the engine compartment, but can't seem to locate it. Can anyone tell me where he should look?
    Marine Power 5.7 in your boat??
      No, Marine Power 6.0
      Sent from my SM-G950U using Tapatalk
        Will try and post a pic tomorrow
          That would be great!!!!
            I havent had time to go snag a pic. Dealing with a massive overheat from winterization done wrong(not by us thank goodness). Will try and go snag you a pic at lunch. Have an older RZ4 on the lot that I'm pretty sure has the 6.0
              It is the capped plug.
                Thank you so much!!!!
                  Update: I did finally find the data port! However, it was VERY hidden! It was tucked up under the overflow tank of the closed loop cooling system. I had to take the center section of the rear seat out, in order to get it plugged in! Whew!!!!
                  Thanks again for the photos... Even though it wasn't where it SHOULD have been, at least that showed me what to look for!
