Just purchased a 2008 Tige Z1 with the 5.7L Vortec 340 v drive. Took it out on the first run last night. Ran great for an hour or so pulling kids on tubes, wakeboard, etc. Close to sunset we stopped for one last change of wakeboarders before we were going to head in. While idling the boat sputtered and turned off. I waited about 3-4 minutes and tried to start again. The first time it would turn over and run for about 2 seconds before sputtering off. My immediate second try it would not turn over, just the starter engaging. If I waited about 3-4 minutes this same process would repeat. After a few phone calls to friends i ended up going two things. 1) I pulled the distributor cap plug off and pressed back on firmly. 2) I could loosen the knock bolts by hand which I was told should not be able to happen. I unplugged the knock sensor connector, blew in it, and reconnected firmly. Then tightened the bolt with my hand as hard as I could. I repeated this on the other side. Gave it a few minutes and the boat started right up and ran like it did before.
Has anyone else experienced this? I thought the knock sensor would only diminish the power, not stall the boat out completely. Or perhaps it was the distributor plug that fixed it?
