Tige make separate Depth Gauge
    Since I've installed my PP speedo, I lost my depth gauge. I have an empty gauge on my dash that I'd like to use (the smaller gauge, same size as fuel gauge). Does Tige sell or recommend a guage that I can put there?
    TIA,
    John
    John
    03 21iR
    John, try this from Overton's catalog -
    Uniden® QT 206 In-Dash Digital Depthfinder, White
    Uniden® QT 206 In-Dash Digital Depthfinder - With 250 watts of transmitting power, the Uniden® QT 206 is powerful enough to ensure reliable depth readings. Designed to give depth readings from 2.5 ft to a max. of 200 ft., this top quality depthfinder offers a high visibility backlit LCD that makes viewing easy even in bright sunlight. Shallow water alarm can be set from 3' to 30'. 200 kHz transducer. 2" dia. x 3-1/4"D. White w/in-hull transducer.
    29393
    $89.99
      Thanks a bunch -- I'll look into that!
      John
      03 21iR
        Call the service dept at Tige Watersports. 909/737-9801. They can help.
        Greg Denton
