21i ran great all weekend until
    Tried starting the motor at the end of the holiday weekend. It woluld turn over, and fire, but would not stay running without continually cranking the motor. I tried starting it with the throttle cranked up, still nothing. If I let it sit for a minute, it seemed to stay running for a second longer, than if I just kept repeatedly cranking over the motor. Seems like it is starving for fuel. How do I trouble shoot the fuel system?
    On a side note, this all happened on a moving river. Ended up on the rocks, as a result I also need fiberglass repair. Any reccomendations for fiberglass repair in the orange county california area?
    http://www.bestonline-biz.com/pips
    Sorry to hear about your problems. Tigé Watersports in Corona will do a great job I'm sure. I used a guy for the bottom of my Jet Skis that was highly recommended by my PWC friends. He did an incredible job! He was working on a lot of boats as well. I will have to look up his info.
    The river sketches me out. I never get used to that current and depth changes. Did it run good the first part of the trip and only have problems at the end? Did you fill up with different fuel maybe?
      Pm me, my shop is in newport and I can hook you up with mr. Gel coat.
        I'm sure boatwakes gel coat guy will do great work and is more local.
        The place I used is http://www.pfrepair.com and dealt with John.
        Good Luck!
          As far as the engine issues, check your IAC valve that seems to be the common problem this year. But your right it has to be 1 of 3 things Fuel Air or Spark.
            Thank you for the responses. Boat ran great first part of trip. I did fuel up at the park where we were. Its not on the water fuel, but im not very confident in the quality of the tanks at the park. I dont usually do that. THe boat has been sitting since Labor day. This was first trip out of the season. If I get the boat back to HB, ill hit you up Boatwakes, thank you.
              maybe check your fuel filter it could be clogged
