Engine doesn't start
    A couple time this past week the boat doesn't want to start...2006 22i Riders Edition
    It turns over but wont fire up
    Things I checked...
    Spark is there
    Injectors are firing
    Spark plugs are changed
    Fuel comes out of shrader valve, pressure not checked yet
    Sometimes it starts perfectly but then when you shut it off it won't start back up...
    Gonna check the fuses tomorrow in the Marine Power relay/fuse box on top of engine
    Where is the ECU located?
    What else can I do?
    Thanks
    Rodney
    If you can apply throttle in neutral and it starts it will be your idle air control valve (iac).
      I tried that with no luck
        I changed the crank sensor, cam sensor, cap and rotor...
        Fired right up...purrs like a kitten
        The cap was pretty corroded/oxidized inside also...probably was the whole cause
          This past summer I had the same issue, diificult and extended cranking, happened a couple of weeks in a row. I found the same thing, contacts in the distributor cap were all funked up with corrosion. Replaced it and the rotor, all good to go.
          I don't want to go to work, take me wake surfing instead!
