Is there any place to buy a programmed ecm for a 5.7 Marine Power other than Marine Power?
Where to buy a ECM other than Marine Power
Long story short.... I had a 2 battery setup with a isolator. I put my boat in the water and it would not crank, so I disconnected the aux battery and cranked the boat with the cranking battery. I ran it for 30 mins and rebooked the aux battery and as soon as I hit the key it went into limp mode. I disconnected the aux battery again and it's still in limp mode. I replaced the batteries, cap, butto, plugs and wires and now the cylinders are losing up with gas. I took it to a mechanic and he said it was the ecm. I've talked to several different mechanics and they all say it's the ecm. I can not find anyone in the state of alabama who has the equipment to scan it.Originally posted by JLG View PostIf I may ask what are you needing and ECM for or why are you replacing it?
Just want to chime in. I have the marine power motor in my boat. Calling them is very helpful, they are really nice and willing to try and solve your problems. I had an alternator question about running a ton of ballast pumps. I also have to say that the marine power motors are great, seems like they have a bit more torque than the current motor tige uses. I have great gas mileage and more power than I need in an 2007 rz22007 RZ2 Marine power 340hp Custom ballast
Tundra Crewmax 5.7L
First thing I would do, correct the battery bank wiring. Whether or not it shorted the ECM, there seems to be an issue there.
Nelems Marine in Jasper AL used be a Tige dealer. I dont see why they cant diagnose it.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
