Can anyone tell me where the TAPS pump/reservoir is on a 2004 22i?
TAPS pump location
I have 2 batterries on the left side and a shower on the right (I forget which is called port or starboard). Nothing is near the batterries but when I removed the shower located on the right rear access panel, I found a small black box. Nothing was written on it so I'm wondering if that's my TAPS pump/reservoir?
If it had two small shiny black hoses coming out of it, then that would be the TAPS pump.Originally posted by jsz View PostI have 2 batterries on the left side and a shower on the right (I forget which is called port or starboard). Nothing is near the batterries but when I removed the shower located on the right rear access panel, I found a small black box. Nothing was written on it so I'm wondering if that's my TAPS pump/reservoir?
Hey
I just bought a 2001 20i and can't find the TAPS pump/reservoir location....any ideas?? My TAPS system kinda works. The switch on the handle moves the flap from full up to about 25% down....but the TAPS gauge doesn't show any movement. If is has a pump with ATF fluid i'd like to check that first.....but cant find it.
Cheers!
