Help with Strut
    Help with Strut
    Hello everyone! Im new to the boating scene and I recently purchased a 96 Tige and on my first outing I hit a rock and bended the strut. Any help on where can I buy a new one or can I get it repaired/fixed? Any feedback will be helpful. Thanks
    Luis Garcia
    To give a better description is a Pre 2002 - 20'
    Luis Garcia
      Welcome to the site. Sorry you had a bad outing your first time out.
      With little information I would say try your dealer.
      If you can add where you are located and possibly some pictures others may be able to join in and give you a better recommendation.
        I'm in Lancaster,Ca
        Luis Garcia
          There's a Tige Dealer in Corona / Pomona. Ummmm I had the same boat, but never bet a strut. Not sure how hard it is to get off, but Im sure it can be replace or repaired without a huge amount of trouble. Are you mechanical at all?
          So this monkey walks into a bar...
            If you bent the strut, you probably bent the shaft and prop as well. It's about a $1500 repair. You can get parts and do it yourself, but if you've never aligned a prop shaft, you probably want to have a professional do it. My $.02
              My local high end machine shop straightened my strut back out. Hopefully it's straight!
                Yeah I noticed that in Corona there's a Tige dealer. I'm going to give them a call to see if I can order it through them. Im sure I can buy it through them but at a full retail price. I was trying to avoid the dealers since they mark up the price on everything. My other concern is that the shaft might be bent but I can't tell from the naked eye.
                Luis Garcia
                  I got the new prop, now I need the strut but Im thinking Im going to go through my insurance company and keep the prop I bought as a back up spare. I will feel much more at ease if the job is done by a professional once I put the boat back on the water. I was trying to avoid submitting a claim.
                  Luis Garcia
                    I dont know of any machine shop that can straighten the strut around Lancaster,CA. Being new to boating I dont know that's if thats even an option? The strut can be straighten out?
                    Luis Garcia
                      Again, depending on how bad it was. It's a cast steel item. Shouldn't be a big deal. Just look for a local machine shop. Im sure Lancaster or Palmdale will have several.
                        Mine was bronze and seems to work great after the guy fixed it. 45 bucks vs 400.
                          Thanks Duff, Im definitely going to look into it. Thanks for the advice
                          Luis Garcia
