So I am doing my own oil changes starting this year. I do not have a manual and the site doesnt provide one for my old boat so does anyone know the OEM reccomended weight and brand for the 5.7 liter Mercury 350?
Proper Oil Weight Question
I use straight 40W, but here is a link to Mercruiser"s diagram.
http://www.mercurymarine.com/service...qs/fueloil.php
Thanks Mike, I bought 10W-40 but then thought I should double check with the experts.Originally posted by TeamAllen View PostI use straight 40W, but here is a link to Mercruiser"s diagram.
Well at the time i bought it the guys at the shop were like "umm that should do the trick" I am going to do the change this evening but think I will go back and exchange for 10W-30.Originally posted by 2whlin View PostI have a 2001 21i with the Mercury Mercruiser 350 MAG MPI. I called Tige and a local dealer and neither of them said there was a problem with running a straight 10W-30. I just changed my oil and used Pensoil 10W-30.
Why 40w?
I don't think it matters. As long as you have the proper amount and change it regularly. Something I did notice when I changed the oil. When checking the oil on the dipstick it still looked clean but when I drained and pulled the oil filter it was darker than what it looked like on the dipstick. Maybe it was that way, just an observation.
I have 10w-40 in my boat from last season, changing it this weekend finally. Just make sure you let your engine warm up good before you get on it and you'll be fine. This has never been a problem for me since it takes a good 10-15 minutes for the truck driver to park and get back to the boat before we leave the no-wake area.
I have a slightly different take...
I have always done my oil changes since day one. Usually use a MerCruiser, Quicksilver type oil filter although I have used a Mobil 1 from time to time depending on convenience. I have used Mobil 1 synthetic either 10w/40 or 20w/50 for 10 years and almost 700 hours. Had several conversations with MerCruiser and other manufacturers as boat maintenance is an interest of mine. MerCruiser 315MPI. Maybe I should change my oil selection....
