Knowing that the transom eyelets are meant for lifting the boat onto a trailer or a boat stand tells me that they are meant to handle the weight of the boat distributed in three places. The bow eyelet and the two transom ones.
In short hauls say from house to lake ie. a couple of miles may be ok but IMO using the swim platform brackets I would suspect that in a panic stop that the brackets will bend or worse.
If the concern is the web strap rubbing the gel coat slide a thin tube sock cut open so that the sock can slide down the strap. You may have to pull the platform pin and slide the sock between the platform and then push platform up so pin can be re-inserted. This slight inconvenience will protect the gel coat but will allow you to properly tie down the boat as it was designed to handle.
If you have a teak platform and are concerned about the tie down strap and the gel coat when using the lifting eyes and sock cannot be slid down between platform and gel coat you may want to sand the platform 1/8" or so to allow the sock to be pressed between the teak platform and the gel coat. Mens tube socks work well for this work around. Heck you could even die them to match the gel coat behind them.
