Originally posted by skyski_tige
View Post
securing your boat and gear from thieves
If you speakers have the 4-way Speakon connectors, then get a car alarm with "door open" inputs. Run a pair of 22ga wire up the tower to the plug. inside the can wire from -2 to +2. When the speaker is plugged up, you have a closed circuit, if the speaker is unplugged or the harness is cut, the alarm sees an open circuit, like a door opening, and sounds off. You can do all the tower speakers and add a switch to the console door with one series loop.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yeah, do you know where I can get one of those car alarms?Originally posted by chadster2 View PostDid you ever see the James Bond where the car exploded when the bad guy tried to break the window with a gun? I’m just saying……Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
damn totally beat me to it.Originally posted by chpthril View PostIf you speakers have the 4-way Speakon connectors, then get a car alarm with "door open" inputs. Run a pair of 22ga wire up the tower to the plug. inside the can wire from -2 to +2. When the speaker is plugged up, you have a closed circuit, if the speaker is unplugged or the harness is cut, the alarm sees an open circuit, like a door opening, and sounds off. You can do all the tower speakers and add a switch to the console door with one series loop.
For a more novel approach search YouTube for the trunk monkey... That's what I would use"I want to know God's thoughts, the rest are just details"
