My rear axle was so hot the other day that it blew both buddy bearing bras off. And all I did was take it for a 10 mile drive. Let me give you the background before you guess at the problem.
It is an '02 trailer with surge disk brakes on the rear axle and even though the bearings have never been repacked, both axles get a few shots of grease before each trip (enough to make the buddy bearing indicator ring move). After a few months in storage, I decided to fill the gas tank. when I got to the gas station (5 miles away), there was a slight burning smell. It smelled like electrical so I looked around but nothing stood out. When I got home, the smell was worse and I noticed both rear bras were gone. That is when I noticed how hot the rear tires and rims were. Very hot compared to the front axle that was still cold.
I wondered if the brakes could have been activated the whole way but it seemed to drive fine. When I jacked the rear axle up, both tires spun normally.
My next guess is a problem with the bearings but I've heard keeping them topped off with grease should keep them OK.
Have any of you experienced anything like this? What was the problem?
I had to put new seals on but the bearings were fine. Also changed the brake fluid cause when it boiled it got very dark. One of the calipers had corroded slides. Enjoy!
