After last years dead battery episodes I decided to add a second battery and purchased the Blue Sea Add a Battery System. Problem I am having is setting this up with my current single battery configuration. Here is what I have.
Neg Cable is coming from the engine block to the Neg Battery terminal. There are a few smaller ground wires connected to the Neg terminal as well. On the Neg battery terminal I also have a good size Pos wire going to stereo amps
Pos cable coming from the starter (smaller cables goes from starter to Alternator) to the existing battery cut off switch. Out the other side of the battery cut off switch I have a 2 Pos wires coming out. One goes to the battery and a smaller one goes to a Pos distribution block, which has other smaller Pos wires going to who knows where. On the Pos battery terminal I also have a good size Pos wire going to stereo amps.
Question is how to reconfigure for the Add a Battery system, the diagram they sent is lacking in my opinion, but then again I am a novice at this.
