So the Tige web config tool provides the "standard" gel coat options available on the 09s.
But there is at least one, and probably two, additional options not reflected.
FIRST: full extension deck accent. See pics. It looks like wetsounds1 had the inaugral RZ4 with such feature followed by the Surf Expo demo RZ2 (pics of both above). This allows the front surface of the pickle, the seat of the transom, and the top deck surfaces to be a lighter color when you go for a dark bow to stern deck accent color.
SECOND: two-tone transom (above swim platform) with solid color sides (i.e., main and second panel same). See pic. Only pic of this feature I have seen is Spolk69's sick RZ4. This allows some transom coolness when going with the slick solid side look.
According to the Tige website config tool, the second color on the transom (above swim platform) is tied to the setting of the second panel. Select black hull, frost main panel, and frost second panel. Result = no black color above swim platform. Now add black second panel (ie, black hull, frost main panel, black second panel). Result = black pattern above swim platform, i.e., "two-tone transom". The only difference between these two configs is the second panel. Thus, according to the web config tool, the second color on the transom (above swim platform) is tied to the setting of the second panel. The Hull color impacts the color below the swim platform of course.
Bonus (non-gel) option: dual underwater transom lights. PDF spec sheet lists on "light" (singular).
Bonus (non-gel) option: zip on bimini extension. Looks to be 2 ft in pics. But there seems to be an option for an 8ft bimini. Is this another extension or a full bimini?
Bonus (non-gel) option: WS420 EQ and PA. Not listed in Tower of Power but seems to be available wired from factory.
Bonus (non-gel) option: docking lights mounted in front hull (as distinguished from docking lights on tower). PDF spec sheet lists twice but does not clarify the second listing is in hull.
Any clarification of above options (especially gel, and especially by Abilene) is much appreciated.
Anyone aware of other options (gel or otherwise) not reflected on the Tige website?
