Any suggestions on wetsound amps for my system, triple x sub, threesome on the tower, six cabin speakers? thnx.
amp question for tim at wetsounds
Of course
3-Some on the tower=SYN 6.
One of the design functions we did with this amp is design it to run the 3-Some as well as in boats and subs or in boats and towers etc...It has high pass on chs 1 to 4 and high pass or low pass on chs 5/6. So this one amp can do a ton of different set ups.
So for the 3-Some. it will run in 3 ch high pass mode. 200x2 and 600x1. 200 to each pro 80 and 600 to the 485.
It also has sum mono capability. So you hit the switch and it sums the signal to sum mono for the single 485 etc..and also RCA summing. So you just put in one set of RCA's and it will go to all chs. So easy install.
You can download the manual here http://www.wetsounds.com/media/produ...yn6_Manual.pdf
It has a diagram to run the 3-Some.
For the in boats and XXX sub= SYN6.
You can run the 3 pairs of in boats and the XXX sub all off the SYN6. Run one pair of in boats off chs 1-2, the other 2 pairs off chs 3-4. Then run the sub in series as a 4 ohm load and bridged mono low pass on chs 5-6. 60x2, 155x2 and 600 x1.
The XXX can handle 1000 watts rms. But if you build the ported box in the XXX manual. 600 watts is good power for it.
So 2 SYN6 will do the entire system.
If you opt for more power. You can run the in boats off a SYN4. And use a SYN1 for the XXX in parallel 1 ohm load giving it 1000 watts.
Option 1: Two SYN6
Option 2: SYN6, SYN4 and SYN1.
Tim
Wet Sounds
If i was putting this setup together, I would deff. go with the Syn6 for the cabins, Syn4 for the cabins, and the Syn1 for the W/S-XXX
X2 on the customer service from everyone there
So, what are you waiting for? You could be the first one on your block with the new toy!Originally posted by jwanck11 View PostI have not seen/heard any wetsounds installs here on the east yet.
C'mon now, be a trend setter.
Is that an order then?
So Bentone....
Shall we get those coming? or are you waiting for a while?
BTW one last session on Sunday then I am out of town for a week (Surf Expo In Orlando) then back to the fall grind and hopefully one more session. Maybe we should have a "skip day" if we get a nice day of Indian Summer.
Tom"Half the money I spend on advertising is wasted....the problem is I don't know which half."
I will take the SYN 1,4,and 6 when you get around to your order, I am also wondering if I should wait and see what this new ballast system is all about on the 09's, I hear it may be awhile for the quick fill/empty on the internal system. I'm liking the looks of the rz with the new tower. So when are you going to get one of these puppies to your shop? I need a test ride before committing you know.Originally posted by empty_boat View PostSo Bentone....
Tom
By the way, you suck, you should love the fact that this is a business trip, right? I wish I could make it. Any time you feel the need for a skip day you let me know and will be there. talk soon....
