What do I need to do to winterize my 24v in AZ. I keep the boat in the garage and it will not freeze in there. Thanks in advance.
Winterize in Arizona
Probably not much. If you're using it occasionally, you should be ok.Originally posted by Methu969 View PostWhat do I need to do to winterize my 24v in AZ. I keep the boat in the garage and it will not freeze in there. Thanks in advance.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Change oil, trans fluid, and V-drive fluid.Originally posted by Methu969 View PostWhat do I need to do to winterize my 24v in AZ. I keep the boat in the garage and it will not freeze in there. Thanks in advance.
Replace fuel filter/water sep
Add a bottle fuel stabilizer to the tank and run the engine for about 10 mins.
Lube steering cable and rudder
Top off the charge in the batteries.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
chpthril,Originally posted by chpthril View PostChange oil, trans fluid, and V-drive fluid.
My steering cable is a little stiff, could you tell me a little on the process of adding lube to the steering cable and rudder?
ThanksThe laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
There should be a zerk on rudder box for a std grease gun. For the cable, turn the wheel so cable is all the way out (in the bilge), give it a shot of W/D 40 and the turn the wheel lock to lock 3-4 time. I do this a few times a yr, and just lube the box in the fall.Originally posted by eks View Postchpthril,
Thanks
I'm gonna try (i cant remember who posted it) the idea of injecting anti-freeze into the cable sheath at the helm using a syringe, to reduce/prevent rust and lube cable.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Thanks, I'll try that.Originally posted by chpthril View PostThere should be a zerk on rudder box for a std grease gun. For the cable, turn the wheel so cable is all the way out (in the bilge), give it a shot of W/D 40 and the turn the wheel lock to lock 3-4 time. I do this a few times a yr, and just lube the box in the fall.
I'm gonna try (i cant remember who posted it) the idea of injecting anti-freeze into the cable sheath at the helm using a syringe, to reduce/prevent rust and lube cable.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
The other thing to do would be to turn the wheel so that the cable is all the way in when you're not using your boat. That way, if there is water in the bilge, it's not affecting the end of the cable.Originally posted by chpthril View PostThere should be a zerk on rudder box for a std grease gun. For the cable, turn the wheel so cable is all the way out (in the bilge), give it a shot of W/D 40 and the turn the wheel lock to lock 3-4 time. I do this a few times a yr, and just lube the box in the fall.
I'm gonna try (i cant remember who posted it) the idea of injecting anti-freeze into the cable sheath at the helm using a syringe, to reduce/prevent rust and lube cable.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Hey fellow TucsonerOriginally posted by Methu969 View PostWhat do I need to do to winterize my 24v in AZ. I keep the boat in the garage and it will not freeze in there. Thanks in advance.
We keep ours covered outside, but don't do much to it for the cold month(s). I take all the little plugs out of the cooling system so there's little or no water in the engine, turn the wheel so the steering cable is fully retracted, and pour some stabilizer in the tank. I also prop open all the various compartments including the engine to avoid trapping moisture.Nostalgia isn't what it used to be
