Originally posted by chpthril
View Post
2009 rz4 with pcm 409
Post some pictures of the wake when you get a chance. Great boat, enjoy it!Originally posted by SPOLK69 View PostYES IT IS THE NEW SWIM PLATFORM IT DOESNT CUT THE WAKE AT ALL WNEN SURFING. 900 LB IN FLOOR BALAST 48 MPH GPS WITH FULL LOAD.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Wow 48mph is impressive IMO with full ballast and load. Sounds like that PCM is a strong motor.Originally posted by SPOLK69 View PostYES IT IS THE NEW SWIM PLATFORM IT DOESNT CUT THE WAKE AT ALL WNEN SURFING. 900 LB IN FLOOR BALAST 48 MPH GPS WITH FULL LOAD.If you ain't falling.. you ain't trying hard enough..
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Do you have any pics of the ballast valves and how it works?
No one seems to know how much weight the new ballast holds, any idea? You might have to truck the boat with full ballast to a truck stop, weigh it and then dump the water, then weigh it again. Could you do that for us please?
Be excellent to one another.
Originally posted by talltigeguy View PostDo you have any pics of the ballast valves and how it works?
ok thats crazy. im sure it is 900 but i want to know how fast it fills and if they are using gate valves on the back or something like that.
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Jake,Originally posted by jake's02-22i View Postok thats crazy. im sure it is 900 but i want to know how fast it fills and if they are using gate valves on the back or something like that.
There is some info on other threads about the new ballast system, but here is the deal: There are 3 inch holes in the transom of the boat that go into an enclosed portion of the hull. You hit a button, and the gate valve opens and within 30 seconds, you have 400 pounds or more in that part of your hull. To empty, you open the valve and drive away, just close the valve before you come off of plane or it will refill as soon as you stop. I think it deserves a lot of hype. It can all be under the floor.
If it lives up to its billing, I think this is the single greatest thing for Tige in recent years, with the PCM upgrade a close second.Be excellent to one another.
JSTIII
Thanks for updating. Also please note that if you go to the following web site http://www.tige.com/downloads.php and go to the owners manual(page 1-7) under tige GM vortec engines, it talks about marine power and not PCM May want to change this also. Under the specification section Need to change the spec on the RZ4 to show the 4485 weight and not 3954. It cant be only 54 lbs more than the RZ2.Last edited by gman; 08-30-2008, 02:13 AM.
