Anyone know where I can get a 14lb cap for the freshwater coolant resevoir on my 20V? Also what is the red light next to the steering wheel an indicator of on a 2005 20V....thanks!
2 questions.....
1. I think you should be able to get the 14 lbs cap at any autoparts store.
2.The red light is a trans lite. it goes out after 1000 rpm or 1500. So it is normal if you are just idle around a marnia to be on.
If I am wrong someone will chime in.
Good luck, doesn't sound like much of a problem.15 Escalade ESV-Black
08 RZ2-Blue
I think the red "TRANS" light is actually for the V-drive. It says "TRANS" on our boat, too, but the sensor is on the V-drive. It is normally ON below 2-3 psi and will go out above that pressure to indicate the gears are getting adequate lubricant flow.Originally posted by samw View Post... 2.The red light is a trans lite. it goes out after 1000 rpm or 1500. So it is normal if you are just idle around a marina to be on.
If I am wrong someone will chime in....
R&T Babich is right, it's the V-Drive light.Originally posted by R&T Babich View PostI think the red "TRANS" light is actually for the V-drive. It says "TRANS" on our boat, too, but the sensor is on the V-drive. It is normally ON below 2-3 psi and will go out above that pressure to indicate the gears are getting adequate lubricant flow.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
