I have a 2000 22i. I changed the impeller out this spring as part of general maintance. I been to the lake on two different occasions and when I started the boat the belt slips. In between the two trips I have been out several times and the boat has run great. When I take the impellar off and open it up the blades are folded backwards. Do I need to replace the belt?
Impellar Question
For some reason, your engine is wanting to roll backwards when you shut it off. This will cause the impeller to flip, and belt to slip when re-fired.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Sorry, my thinking hours are from Mon to Fri 9-5, please check backOriginally posted by anmalone View PostDo you know what the solution to this is? Is it a problem?
J/k, Timing, leaking fuel injector, idle speed too high for starters.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Expert- Mar 2008
- 1396
- The Sunshine State
- 2000 Tige 21I Riders Edition, 1980 MC Stars and Stripes
I believe the RPM at idle is 650. Somebody will verify that."I feel sorry for people that don't drink, when they wake up in the morning, that's as good as they're gonna feel all day" - Frank Sinatra
The sticker on our 1999 Merc MAG MPI says idle is 600 RPM.Originally posted by Fast1911 View PostI believe the RPM at idle is 650. Somebody will verify that.
How many hours on the engine?
The only time I've had an engine reverse when stopping is because the timing chain was stretched from lots of miles. Put a big ratchet on the dampener bolt and turn it backwards just a little, then in the direction of normal rotation while watching the distributor rotor. If the ratchet turns a lot before the rotor turns the chain is stretched.
