The 400# V-drive sac is 16" tall when filled.....this leaves 7" to the storage door.
New Boat Questions
Thats not a lot of room & definitely not enough room for a cooler.Originally posted by chpthril View PostThe 400# V-drive sac is 16" tall when filled.....this leaves 7" to the storage door.
The batteries are located on top of the hard tanks in the rear of the boat. I guess they are not easily accessible, but there is an extension in case the batteries need to be jumped.www.integrity-wake.com
The batteries are located in a box in the storage that is built to make room for the tanks. The batteries are actually easier to get to on boats with ballast then with out.Originally posted by Jeffe View PostThats not a lot of room & definitely not enough room for a cooler.
The batteries are located on top of the hard tanks in the rear of the boat. I guess they are not easily accessible, but there is an extension in case the batteries need to be jumped.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
X2.Originally posted by chpthril View PostThe batteries are located in a box in the storage that is built to make room for the tanks. The batteries are actually easier to get to on boats with ballast then with out.
The batteries are not on top of the hard tanks in boats with ballast, unless you know of some new system.Be excellent to one another.
Yeah, I cant speak for what your dealer does in his own shop, but just trying to describe how the boat will come from the factory with or with out ballast. Not sure how they mount batteries on top of a hard tank that fits under the transom with > 1" clearance.Originally posted by Jeffe View PostThis dealer builds a separate box and locates the batteries on top of the ballast.
Here is a pic of the RZ2 rear storage with ballast. You can see the battery box taking up storage because the factory hard tanks run across the transom where the battery would sit.
Pics please? I'd love to see this!Originally posted by Wet Sand View PostMy '07 RZ2 was purchased from Tige Watersports. They added an additional battery (total 2) and repositioned them to the top of the hard tanks leaving the entire storage space usable, except for the perko battery switch mounted in the corner upper right rear wall.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Daniel at Tige Watersports told me about this setup, I would like to see pics as well.Originally posted by Wet Sand View PostMy '07 RZ2 was purchased from Tige Watersports. They added an additional battery (total 2) and repositioned them to the top of the hard tanks leaving the entire storage space usable, except for the perko battery switch mounted in the corner upper right rear wall.
