I am just waiting for them to have a real ballast system that competes with everyone else. The 900 pounds doesn't cut it. I love how Supra has theirs, you can start with a small ballast option but have the option to upgrade to Gravity Edition soft bags. I am jealous of my buddies Supras their ballast bags are huge and hold a ton of weight.
New Tige Ballast system?
Originally posted by Matt Garcia View PostI am just waiting for them to have a real ballast system that competes with everyone else. The 900 pounds doesn't cut it. I love how Supra has theirs, you can start with a small ballast option but have the option to upgrade to Gravity Edition soft bags. I am jealous of my buddies Supras their ballast bags are huge and hold a ton of weight.
Matt, we can make yours the same way. EKS did a nice system.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
We did the same type but EKS used 800# in the lockers I used 400#'sOriginally posted by Matt Garcia View PostHow did he do it? Have a link anywhere?
Mine
http://www.tigeowners.com/forum/show...ey%27s+ballast
EKS
http://www.tigeowners.com/forum/show...ballast+systemPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
So where is the sign up form?Originally posted by G-MONEY View PostWe did the same type but EKS used 800# in the lockers I used 400#'s
Mine
EKS
eks ballast does look nice. My quandary is that I have the stock ballast system and would like to add more to it via some soft sacs. I haven't seen anyone do this yet. The bow is another issue, right now I have the integrated bow sac but I have it maxed out. So lead or adding another bow sac is the only solution, I dont mind filling one sac but three gets old.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
I have seen people just plum in the new soft sac's.
Just hook your vent line in to the sac and add a new vent line from the sac out of the boat.
So after the hard sac fill they overflow in to the soft sac to fill it.
MC guys do this on the X2 and X stars...Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Ya I have discussed that on here as well with a few other members but the theory we have concluded is that water would "trickle" out of the vent line into the new sac. In other words it wouldnt have much pressure or water flow to fill another 500 pound sac.Originally posted by G-MONEY View PostI have seen people just plum in the new soft sac's.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
How fast does the water come out your vent port?Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
How would you drain it? the Tige hard tanks are up so high.Originally posted by G-MONEY View PostI have seen people just plum in the new soft sac's.
MC guys do this on the X2 and X stars...Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
T into the drain and use some check valvesPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Thats weird I know MC uses the BP and use check valves all over the place...Originally posted by dogbert View PostHmm, the instructions on the Ballast Puppies said to avoid using check valves. Ballast Puppies is what's on the MCs.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Do you have pictures of your install?Originally posted by dogbert View PostHmm, the instructions on the Ballast Puppies said to avoid using check valves. Ballast Puppies is what's on the MCs.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
