Originally posted by chpthril
View Post
G-Money's ballast systems
This was G's and I thought also. Remember there is only two boats so far that have this system. The nice thing about the system is that it can be changed around so easy. If EKSilva has the same problem we may rerout a few things and he may run into a problem where we have to fill from the top of the bag rather than the bottom.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Filling from the top will probably solve the back-flow, but you will still need to drain from the bottom.Originally posted by SPBFAN View PostThis was G's and I thought also. Remember there is only two boats so far that have this system. The nice thing about the system is that it can be changed around so easy. If EKSilva has the same problem we may reroute a few things and he may run into a problem where we have to fill from the top of the bag rather than the bottom.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
I was thinking about doing a T In to the top of the sac with a on way check at the bottom forcing the water to fill from the top.....Originally posted by chpthril View PostFilling from the top will probably solve the back-flow, but you will still need to drain from the bottom.
but that wont stop the water flowing out from the bottom.
I don't have a problem with reaching through the seat with the easy access hole we put in and closing the manifold when the sacs are full.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
Isn't it true that with a pump that sucks air you can actually empty from the top?Originally posted by chpthril View PostFilling from the top will probably solve the back-flow, but you will still need to drain from the bottom.
I think you only have to empty from the bottom if you have aerators, right?Be excellent to one another.
True, sucking air is wat makes them self-priming just like the raw water impellers, but because of the vent line, it will prevent a vacuum in the sac, and this may slow or prevent the emptying by drawing too much air instead of water.Originally posted by talltigeguy View PostIsn't it true that with a pump that sucks air you can actually empty from the top?
Anyway, running these dry is what leads to impeller failure. The more often it draws air, the shorter it's lifespan.
Not if you put in a check valve that would prevent air from getting sucked back into the sack.Originally posted by chpthril View PostTrue, sucking air is wat makes them self-priming just like the raw water impellers, but because of the vent line, it will prevent a vacuum in the sac, and this may slow or prevent the emptying by drawing too much air instead of water.
As for the pumps, they have a run-dry protection that shuts them off when they do.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
The whole hype of this reversible pump system is less plumbing then the aerator style pumps. Now we are throwing extra hose and check valves in in order to stop a common problem with the cheaper aerators.Originally posted by dogbert View PostNot if you put in a check valve that would prevent air from getting sucked back into the sack.
I feel the run-dry protection will one of the factors to come into play when draining from the top of the sac.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
When you fill through the top with a typical aerator pump system, this seems to be almost done by accedent, and most times, seems to work.Originally posted by dogbert View PostWell, my thought was to just raise the level of the hose somewhere between the pump and the sack. This would minimize the back pressure. That's what I plan to do.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
As for the pumps, they have a run-dry protection that shuts them off when they do.If I put a check valve in the vent it will allow me to fill and drain from the top and all I would need to do is add only one check valve to each sac and no extra hose.Originally posted by chpthril View PostThe whole hype of this reversible pump system is less plumbing then the aerator style pumps. Now we are throwing extra hose and check valves in in order to stop a common problem with the cheaper aerators.
This will also prevent the water from draining from the sac.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
That is true. We sure gave it our best shot though. G has a good idea that I think will work though. The main thing is that it hold water and it adds weight to the boat.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
xpjim, this was gold!Originally posted by xpjim1 View Posthere is my last picture from a guy who instaled the jabsco. People told him Seven should be connected to 2
I had three switches, each wired a different way. I guess they don't have QC at Jabsco.
I finally got my ballast system installed. I had to tap into the raw water intake, but overall I'm happy with the results. Those ballast puppies are sweet!
I also got my fuel flow meter installed a couple of weeks ago...now I have to learn how to use it.
After some clean-up my boat is ready for the lake!
Sorry, no pics yet, but I'll get them next weekend.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
