I see you guys with 18'' even 20'' wheels and tires on your trailer. Do you have to do anything special to fit the bigger wheels on?
Trailer Question
I think every dealer gets there own trailers from local sources...tige themselves dont do trailers (I dont think).
So like Timmys case, WWS ordered the trailer special and that manufacture has certain options you can get with their trailers.
Like for my Z1 I could have gotten the 20" rims etc but then it wouldnt fit in my garage so I went with the standard....but I did add the prop guard rollers, pin stripping, led package etc. as an option.
I would assume as well that they do something specific with the axles if you order it with bigger tires/rims. To get them to fit after the fact would take some work I would imagine.
Rock on!Work Hard, Play Harder
Tigé Jedi- Feb 2004
- 5529
- St. George, Utah
Depends on how big the rims are as well. Some just make up for the extra sized rims by slimming down the tires, so the overall diameter does not change and nothing special needs to be done.
IMO, some very nice looking rims could be placed without having to make major mods.
But then you have to consider things like the load capacity of low profile tires as well.Be excellent to one another.
Supreme Tigé Master- Sep 2005
- 9278
- 2005 24v
On a boat 4-5 year maxPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
They make lots of sizes in load range E for 20" I think they make load range E all the way up to 24".Originally posted by TigeDuner View PostI would to see a load range "E" in a 20" tire. It would be solid rubber.....
Question - why would a car tire fail on a trailer when the item being towed is the same weight or less than many cars? My trailer tires are 245/55/20's I think so they are a pretty tall tire.
I'm going through this right now... but I'm sending my trailer manufacturer my wheels and tires to build the trailer around them.
When choosing tires, make sure and use the plus sizing method. Most guys that are using 18's are using 255/45 R18
I'm putting on 19's and using a 255/45/19. The reason I'm using this size is b/c my trailer manufacturer's tallest tire is a 225/75/15 .... if you do the math, these tires are almost exactly the same height. However, the tire I'm using is slightly wider... so this will require a wider fender.
In all honesty, the wider tires aren't necessary. You can get by w/ a narrower tire so you don't have to adjust your fenders on an existing trailer. But you need to be concious of your offset's and backspacing. Your standard trailer wheels usually have a 0 offset. This is going to be really hard to find. A FWD + offset will probably be your best bet on getting wheels to tuck in correctly.
This tool is really great for comparing tire sizes, like when using the plus sizing method.
http://www.miata.net/garage/tirecalc.htmlBeing a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
